AGSLayerDelegate is not being called
1298
03-11-2013 04:58 PM
KyunamKim
Let's say I have my own delegate class
@interface MyLayerDelegate : NSObject <AGSLayerDelegate>
@end
along with its implementation file.
In my ViewController, I set a delegate like this.
AGSDynamicMapServiceLayer *aLayer = ...;
aLayer.delegate = [[MyLayerDelegate alloc] init];
Why isn't this delegate instance not being called?
When I make ViewController to adopt AGSLayerDelegate and do
aLayer.delegate = self;
Then, this works.
Yes, I'm new to Objective-C, iOS land.
Kyunam
FrankXia
You need to hold the reference to your MyLayerDelegate variable so it wouldn't be released by the system. In your controller class's .h file, add the following line,
@property (nonatomic, strong) MyLayerDelegate *myLayerDelegate;
And then create an object for this class in your controller's .m file, and assign to the variable you declared in the .h file such as
    myLayerDelegate = [[MyLayerDelegate alloc] init];
    yourDynamicLayer.delegate = myLayerDelegate;
That's all.
Frank
FrankXia
That's all.
Frank
