Transperant Base/Tiled Map Layer, without opacity setting to 0.
5638
6
06-23-2016 12:30 PM
PritiBose
Hello Everyone,
I need very quick answer as i am really in big issue. my iPad app released yesterday where by mistake i added Base Map layer which should not be case of some of my client.
base map URL  i get from DB, so my question is, Is there any Transperant Base MAP/ Tiled MAP URL i can use.
(i can not change code as i need quick fix by making opacity 0 or anything, changing code i have to get my App approval will taken another 10 days) .
Please do help me out if anything is available. i wanted URL of base MAP which act like transparent Layer like by default Opacity 0 some thing.
so that Client will not be able to see Base MAP.
Please help me out ...its very urgent
Nicholas-Furness
Try this: http://services.arcgis.com/OfH668nDRN7tbJh0/arcgis/rest/services/No_data_tiles/MapServer
I created this by signing in at developers.arcgis.com and creating a new layer at https://developers.arcgis.com/layers/#/new/
I created an empty point Feature Service with a single field and published that.
Then I clicked the "Open in ArcGIS Online" button to see the new Feature Service's item page, and from there clicked "Publish" a new Tile Layer. From there in the Manage Tiles panel I picked the `:147,914,382 scale to create just 20 or so tiles at a cost of about 0.06 credits total.
That generated the tile service link above. You can make use of that for a bit, but I recommend you create your own because I could easily delete that in a cleanup. Sounds like you won't need it for long. Do test that it works as you expect though - in my testing it seems to work, but I might have misunderstood what you want.
Hope that helps!
Nick.
JohnGravois
if you're asking about individual transparent tiles, check out the article below.
How To: Configure the cache folder to display a 'Data not available' tile for empty map cache areas ...
if you're asking whether anyone has created a real map service with cached tiles for the whole world that are all entirely transparent, i kinda doubt it.
Nicholas-Furness
Hope that helps!
Nick.
PritiBose
Hello,
Thank you so much for your help. it worked perfectly. i am using your created layer as of now.
i tried to create new layer as you had suggested, but however i am getting There was an error creating your layer .
could you please help me out here....
thank you,
Nicholas-Furness
Hey Priti,
Glad it worked. Not sure where the process failed, so here's the whole thing, step-by-step: Creating a blank hosted tiled layer
Let me know how that goes.
Cheers,
Nick.
PritiBose
Hello,
i created Blank Layer, you made it very simple.
however once i created i did tried to open on my client machine browser ,
it is asking me 'Token Required', i guess because of this Layers are not
getting loaded.
below is my Layer :
http://services7.arcgis.com/cjiXw9G7MdkRVS7b/ArcGIS/rest/services/Blank_Tiles/MapServer
May be i am missing some setting ?
Thx,
Nicholas-Furness
You probably need to share the layer with everyone.
