SIGNAL 11 Segmentation fault: 11
1452
6
10-16-2024 12:12 PM
RTC
We have been getting a lot of crashes since updating our app to 100.15.6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
VM Region Info: 0 is not in any region. Bytes before following region: 4301357056
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100618000-1006d4000 [ 752K] r-x/r-x SM=COW /var/containers/Bundle/Application/61CC2BA1-D693-4CB6-83CA-58828B94F532/MyApp.app/MyApp
Termination Reason: SIGNAL 11 Segmentation fault: 11
Terminating Process: exc handler [34576]
Triggered by Thread: 0
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 name: Dispatch queue: com.apple.main-thread
Thread 0 Crashed:
0 Runtimecore 0x1023d0c70 auto esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)>::invoke_callable_<esri::common::Signal<void (esri::geomodel::Layer_content const&, bool)>::notify(esri::geomodel::Layer_content const&, bool) const::'lambda'(esri::common::signal_detail::erased_target_base&) const>(void const*, esri::common::signal_detail::erased_target_base&) + 20
1 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
2 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
3 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
4 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
5 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
6 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
7 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
8 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
9 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
10 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
11 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
12 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
13 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
14 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
15 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
16 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
17 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
18 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
19 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
20 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
21 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
22 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
23 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
24 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
25 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
26 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
27 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
28 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
29 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
30 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
31 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
32 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
33 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
34 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
35 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
36 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
37 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
38 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
39 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
40 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
41 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
42 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
43 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
44 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
45 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
46 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
47 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
48 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
49 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
50 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
51 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
52 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
53 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
54 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
55 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
56 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
57 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
58 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
59 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
60 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
61 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
62 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
63 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
64 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
65 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
66 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
67 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
68 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
69 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
70 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
71 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
72 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
73 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
74 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
75 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
76 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
77 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
78 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
79 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
80 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
81 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
82 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
83 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
84 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
85 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
86 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
87 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
88 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
89 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
90 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
91 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
92 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
93 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
94 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
95 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
96 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
97 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
98 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
99 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
100 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
101 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
102 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
103 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
104 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
105 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
106 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
107 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
108 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
109 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
110 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
111 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
112 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
113 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
114 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
115 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
116 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
117 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
118 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
119 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
120 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
121 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
122 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
123 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
124 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
125 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
126 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
127 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
128 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
129 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
130 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
131 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
132 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
133 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
134 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
135 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
136 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
137 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
138 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
139 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
140 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
141 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
142 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
143 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
144 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
145 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
146 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
147 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
148 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
149 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
150 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
151 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
152 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
153 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
154 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
155 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
156 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
157 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
158 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
159 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
160 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
161 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
162 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
163 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
164 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
165 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
166 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
167 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
168 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
169 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
170 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
171 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
172 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
173 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
174 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
175 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
176 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
177 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
178 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
179 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
180 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
181 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
182 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
183 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
184 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
185 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
186 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
187 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
188 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
189 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
190 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
191 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
192 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
193 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
194 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
195 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
196 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
197 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
198 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
199 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
200 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
201 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
202 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
203 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
204 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
205 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
206 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
207 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
208 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
209 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
210 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
211 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
212 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
213 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
214 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
215 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
216 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
217 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
218 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
219 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
220 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
221 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
222 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
223 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
224 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
225 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
226 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
227 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
228 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
229 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
230 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
231 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
232 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
233 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
234 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
235 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
236 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
237 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
238 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
239 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
240 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
241 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
242 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
243 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
244 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
245 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
246 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
247 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
248 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
249 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
250 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
251 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
252 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
253 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
254 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
255 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
256 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
257 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
258 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
259 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
260 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
261 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
262 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
263 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
264 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
265 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
266 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
267 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
268 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
269 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
270 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
271 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
272 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
273 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
274 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
275 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
276 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
277 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
278 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
279 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
280 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
281 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
282 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
283 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
284 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
285 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
286 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
287 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
288 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
289 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
290 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
291 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
292 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
293 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
294 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
295 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
296 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
297 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
298 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
299 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
300 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
301 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
302 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
303 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
304 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
305 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
306 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
307 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
308 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
309 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
310 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
311 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
312 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
313 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
314 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
315 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
316 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
317 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
318 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
319 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
320 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
321 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
322 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
323 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
324 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
325 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
326 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
327 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
328 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
329 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
330 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
331 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
332 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
333 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
334 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
335 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
336 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
337 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
338 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
339 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
340 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
341 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
342 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
343 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
344 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
345 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
346 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
347 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
348 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
349 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
350 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
351 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
352 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
353 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
354 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
355 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
356 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
357 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
358 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
359 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
360 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
361 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
362 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
363 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
364 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
365 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
366 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
367 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
368 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
369 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
370 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
371 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
372 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
373 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
374 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
375 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
376 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
377 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
378 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
379 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
380 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
381 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
382 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
383 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
384 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
385 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
386 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
387 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
388 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
389 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
390 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
391 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
392 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
393 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
394 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
395 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
396 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
397 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
398 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
399 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
400 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
401 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
402 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
403 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
404 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
405 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
406 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
407 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
408 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
409 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
410 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
411 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
412 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
413 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
414 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
415 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
416 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
417 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
418 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
419 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
420 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
421 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
422 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
423 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
424 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
425 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
426 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
427 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
428 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
429 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
430 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
431 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
432 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
433 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
434 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
435 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
436 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
437 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
438 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
439 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
440 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
441 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
442 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
443 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
444 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
445 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
446 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
447 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
448 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
449 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
450 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
451 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
452 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
453 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
454 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
455 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
456 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
457 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
458 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
459 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
460 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
461 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
462 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
463 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
464 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
465 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
466 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
467 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
468 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
469 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
470 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
471 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
472 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
473 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
474 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
475 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
476 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
477 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
478 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
479 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
480 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
481 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
482 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
483 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
484 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
485 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
486 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
487 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
488 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
489 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
490 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
491 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
492 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
493 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
494 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
495 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
496 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
497 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
498 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
499 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
500 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
501 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
502 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
503 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
504 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
505 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
506 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
507 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
508 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
509 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
510 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
rolson_esri
Esri Alum
Is the crash reproducible with 100.15.5? Do you have some reproducible code?
RTC
Yes, it did happen in 100.15.5 but not as frequently. We are not able to reliably reproduce the issue we are just getting reports of it from out customers. Once the error occurs, the user has to restart the device.
rolson_esri
Esri Alum
The backtrace looks like maybe the user was changing visibility on a layer. Can you talk about if your app allows for that and what kind of layers it allows changing visibility on?
RTC
Yes, the app allows the user to toggle the visibility of all layers in a map, excluding the base. Additionally, there can also be graphic layers added to the map at runtime and these layers can be toggled as well.
rolson_esri
Esri Alum
Any more specific details we can get about layer types that are in the user's maps would be helpful. If you can try to reproduce the issue by using your app to toggle layer visibility and let us know what your code looks like that does that, and what kind of layer caused the crash, that would be helpful. In the absence of a reproducible case it is very difficult to find and fix these bugs. Thank you.
Other information that would be helpful is what kind of device, what version of iOS or iPadOS was the device running.
RTC
We are working to try and identify any patterns but so far have not been able to. The maps and layers used in our app are defined by the user so they can include any range of layers and layer types. As for iOS versions, most of our users are on 17 with some on 80. Most of the device types are iPad Pro models.
