Rotate the Map Without annotation layer
3691
08-15-2012 06:43 PM
FrankLin1
Hi~
ArcGIS Runtime SDK for iOS give 'allowRotationByPinching' property to map view to enable 'Two finger Twist' rotate the map.
But if someone knows how can I rotate map without annotation layer ?
Frank Lin
NimeshJarecha
Is annotation layer a dynamic layer or feature layer?
Regards,
Nimesh
FrankLin1
Regards,
Nimesh
Currently it is a tiled layer. Can it works if it is a dynamic layer or feature layer ?
Tks & Bgds
Frank
NimeshJarecha
If it is a feature layer then, YES. You need set the *angle* of feature layer's symbol. The *angle* should be exactly opposite to self.mapView.rotaionAngle. i.e. if self.mapView.rotaionAngle is 40 then you need to set symbol's angle to -40.
Hope this helps!
Regards,
Nimesh
FrankLin1
Hope this helps!
Regards,
Nimesh
I will try to change the service type . Thanks !
Regards.
Frank
FaisalSabri
Hi ,
i have a problem with "allowRotationByPinching" it was working without any problems , but now it's rotating the View not the map
so I'm getting the attached result ..
[ATTACH=CONFIG]22336[/ATTACH]
can you please help meee 😞
