Problem putting a UINavigationViewController inside a callout
2621
07-27-2012 06:25 AM
DanielMonego
I'm implementing an identification workflow that uses a UINavigationController that contains a series of UITableViews that allow the user to drill down into the data. Unfortunately, when I insert the navigation controller view into the callout, it weirdly overhangs the UITableView it contains:
[ATTACH=CONFIG]16435[/ATTACH]
As you can see, the navigation bar overhangs the top row of the table, which is difficult to see and access from under it.
I'm using the following code to put the view up:
-(void)identifyTask:(AGSIdentifyTask *)identifyTask operation:(NSOperation *)op didExecuteWithIdentifyResults:(NSArray *)results
    NSLog(@"Identify task returned with %d results.", [results count]);
    if (results && results.count > 0)
        IdentifyResultsViewController *idWindow = [[IdentifyResultsViewController alloc] init];
        idWindow.results = results;
        UINavigationController *nvc = [[UINavigationController alloc] initWithRootViewController:idWindow];
        map.callout.customView = nvc.view;
        nvc.view.frame = CGRectMake(0, 0, 275, 400);
        [map showCalloutAtPoint:self.mapPoint];
I've played around with setting the frame of the idWindow.view, but haven't had any luck with that. Are there any better ways to get this layout working correctly?
PaulLohr
I wonder if you need to ask the UINavigationController instance for the proper size of the item you are adding to it?
Paul Lohr
Lohr Geospatial Services, Inc.
NimeshJarecha
Just set the navigation view controller's frame before setting it as callout custom view and it should fix it. See code below...
        //set the frame before setting the callout custom view
Regards,
Nimesh
AaronConnolly
Regards,
Nimesh
Is this a bug? Why does this happen with UINavigationController but not with a stock UIViewController? I also noticed that if you set the callout's customView to a generic UIViewController, then some time later set it to a UINavigationController you don't see this issue with the nav bar.
