popup with multiple graphics on graphic click
3121
11-09-2012 06:17 AM
VIKRANTKRISHNA
    I want to show popup with multiple features upon click on graphic. I followed the steps mentioned in this thread http://forums.arcgis.com/threads/63167-Multiple-Features-in-Popup?highlight=popup+click  , but not yet successful. I need to remove the steps of callout and accessory button.  What should I do in mapView:didClickAtPoint to launch popup.
Vikrant
JeffGiesler
Vikrant,
Below is my code for the didClickAtPoint.
-(void) mapView:(AGSMapView *)mapView didClickAtPoint:(CGPoint)screen mapPoint:(AGSPoint *)mappoint graphics:(NSDictionary *)graphics {     PopupGraphics = [[NSMutableArray alloc] init];     for (NSString* key in graphics)      {         id value = [graphics objectForKey:key];         for (AGSGraphic *featureGraphic in value)         {             AGSPopupInfo *popupinfo = [AGSPopupInfo popupInfoForGraphic:featureGraphic];             NSArray *CellBustedValues = [featureGraphic.layer.name componentsSeparatedByString:@" - "];             if (CellBustedValues.count >1)             {                 popupinfo.title = [CellBustedValues objectAtIndex:1];             }             else              {                 popupinfo.title = featureGraphic.layer.name;             }             AGSPopup *popup = [AGSPopup popupWithGraphic:featureGraphic popupInfo:popupinfo];             [PopupGraphics addObject:popup];         }     } if (PopupGraphics.count > 0)     { self.popupVC = [[ AGSPopupsContainerViewControlleralloc] initWithPopups:PopupGraphicsusingNavigationControllerStack:NO];         self.popupVC.delegate = self; self.popupVC.style = AGSPopupsContainerPagingStylePageControl;         self.popupVC.styleColor = [UIColor blackColor]; self.popupVC.modalTransitionStyle = UIModalTransitionStyleFlipHorizontal; // so it doesn't take up the entire screen self.popupVC.modalPresentationStyle = UIModalPresentationFormSheet;         [selfpresentModalViewController:self.popupVCanimated:YES];     } }
Also i found that setting your self.mapView.CalloutDelegate = self in the viewDidLoad turns off the callout box
Hope this helps.
Jeff
JeffGiesler
Vikrant,
Hope this helps.
Jeff
VIKRANTKRISHNA
Hi Jeff,
         I just found the solution from the same post, was about to respond to it.
Vikrant
JeffGiesler
Glad you figured it out,
Cheers,
Jeff
DiveshGoyal
Check out our latest sample showing how to display popups.
