How to save my form details in cache when in  Disconnected network?
3037
12
04-25-2012 12:44 PM
akpagaakpaga
Hi friends,
I am using the Esri ArcgIs app for IOS...have an inbuilt form that does the transfer of data to server to the SDE tables in when it has Internet(3G) connection but i want it to do the same and store it in cache when there is no internet connection...Is this possible on the IOS?
Thanks in advance
NimeshJarecha
There is no documentation for the sample. You can watch the UC 2011 Plenary Video.
The sample only allows to inspect existing features. Do you see callout with accessary button on tap of the feature? If no, just comment out code line as following in the ClipboardViewController.m. Rebuild the project.
- (BOOL)mapView:(AGSMapView *)mapView shouldShowCalloutForGraphic:(AGSGraphic *)graphic {
    //self.mapView.callout.accessoryButtonHidden = (graphic.layer == self.inspectionLayer);
    return YES;
Now you will be able to see the accessory button and on click of it, you will see a popup with attributes and attachments.
Hope this helps!
Regards,
Nimesh
Is there any documentation on the "Offline Inspections Sample - UC 2011 Plenary Demo" sample?
I have downloaded and configured successfully, but only get so far as being able to click on the green sticky note to "Make sure data is downloaded before going into field" and then clicking on the "Start Inspections" yellow sticky note.
That loads some points on the map, but then I do not see anything else happening, and no other buttons to click, etc...
Is there a video showing this app working or some documentation to assist with getting working and loading my own data into the app?
EricGreen
I was curious if anyone knew how to connect to the sample inspections shown at the UC plenary.  I have the app built and running in the iPad simulator, but of course there are no features.  Opening the settings for the app reveals that that the URLs are blank.  I assume if I had the sample features link, I could then view the features.  I am interested in making a similar app and would like to tie to my own features and replace the offline tiles.  Is there another link that offers more info on this very cool project?
Eric
MattSheehan
I thought it worth mentioning some work we have been doing using Mobile Flex with online/offline editing. Here is a demo and more information:
http://www.webmapsolutions.com/free-arcgisonline-mobile-offline-editing-app
--Rory
