how can i get AGSRelatedFeatureQueryResult with all field values?
2419
7
12-30-2018 08:09 PM
PrasadJ
Please help me to resolve the issue.
i need to display all the field values of the relation table information of a feature on related feature class,
But we are not getting full attribute information
below code snippet
self.featureTableParking.queryRelatedFeatures(for: self.selectedParking ) { [weak self] (results:[AGSRelatedFeatureQueryResult]?, error:Error?) in
            if let error = error {
                //display error
                self?.presentAlert(error: error)
            else {
below is the snippet for extracting the field of "totalspots" but i am getting value of displayFieldName
    let result = self.results[0]
        let feature = result.featureEnumerator().allObjects[indexPath.row]
        let displayFieldName = result.relatedTable!.layerInfo!.displayFieldName
        let fields=result.relatedTable!.fields
        print(fields)
       let value1 = feature.attributes.value(forKeyPath: "TOTALSPOT")
     print(value1.debugDescription)
how can i get all the attribute information of all field
NimeshJarecha
Hi Prasad,
What result you see for the following code? Does it print only one field or all fields?
        print(fields)
Regards,
Nimesh
PrasadJ
Hi Nimesh,
It is printing all the fields info but corresponding values not getting.
Regards,
Prasad
NimeshJarecha
Hi Prasad,
Can you post result of following print statements. I would like to see how many fields are present and what attributes you are getting.
        print(fields)
print(feature.attributes)
Regards,
Nimesh
PrasadJ
Dear Nimesh,
Below is the result we are getting. i need all the attributes value but we
are getting only 3 fields value.
Please suggest
print(fields)
Result:
*[Name:OBJECTID; Type:8; Alias:OBJECTID; Editable:0, Name:FACILITYID;
Type:7; Alias:Space Identifier; Editable:0, Name:SPACENAME; Type:7;
Alias:Name; Editable:0, Name:LOCDESC; Type:7; Alias:Location; Editable:0,
Name:OPERDAYS; Type:7; Alias:Operational Days; Editable:0, Name:OPERHOURS;
Type:7; Alias:Operational Hours; Editable:0, Name:RESTRICTION; Type:7;
Alias:Parking Restrictions; Editable:0, Name:TOTALSPOT; Type:0; Alias:Total
Spots; Editable:0, Name:OWNEDBY; Type:0; Alias:Owned By; Editable:0,
Name:MAINTBY; Type:0; Alias:Managed By; Editable:0, Name:GLOBALID; Type:9;
Alias:GLOBALID; Editable:0, Name:LOCATION; Type:7; Alias:LOCATION;
Editable:0]*
Result:
  • GLOBALID = "F72D453A-30DE-43D3-895D-7232B4E68A07";*
  • LOCATION = P2;*
  • OBJECTID = 11;*
  • SPACENAME = "Second Floor";*
NimeshJarecha
Hi Prasad,
Please use queryRelatedFeaturesForFeature:parameters:queryFeatureFields:completion: method to query related feature and specify `queryFeatureFields` as `AGSQueryFeatureFieldsLoadAll`.
Hope this helps!
Regards,
Nimesh
PrasadJ
Hi Nimesh,
Thank you for your help
it is working fine
NimeshJarecha
I'm glad it worked for you. Can you please mark the answer helpful?
Regards,
Nimesh
