Export Compliance and ArcGIS Runtime framework
1274
03-24-2022 06:23 PM
AndrewMcLane
Hi Community!
Does the ArcGIS Runtime framework contain encryption that Apple considers advance enough to declare yes on the AppStoreConnect upload Export Compliance check?
Thanks!
Nicholas-Furness
Hi @AndrewMcLane,
ArcGIS Runtime does NOT use any form of non-exempt encryption.
From Runtime's perspective you can answer the questions as below (Runtime's use of exempt encryption is highlighted in red)…
and then…
Of course if your own code implements additional encryption, you'll have to take that into consideration. And you may still have an obligation to submit a self-classification report even if your app is compliant.
Hope that helps.
Nicholas-Furness
Hi @AndrewMcLane,
and then…
Hope that helps.
AndrewMcLane
Yes, it helps; and thank you for your swift reply @Nicholas-Furness!
