dyld[1119]: Library not loaded: @rpath/Runtimecore.framework/Runtimecore
8139
12-29-2022 05:22 PM
cb2206
I'm trying to add the ArcGIS iOS SDK to an existing Xcode project. I added ArcGIS via Swift Package Manager as well as by manually dragging and dropping ArcGIS.xcframework and Runtimecore.xcframework into "Frameworks, Libraries and Embedded Content".
With either way, when I compile and execute the project on an iPad Pro with M1 chip or an iPhone 13 Pro, the app crashes at startup with this error message.
What am I doing wrong?
  Referenced from: <EE272319-351D-300E-99E1-CA79CBAD8940> /private/var/containers/Bundle/Application/9DE567C3-D655-4DDE-A7D2-F0DC11BE6911/SMPAgentryClientFrameworkSetup.app/SMPAgentryClientFrameworkSetup
  Reason: tried: '/private/preboot/Cryptexes/OS@rpath/Runtimecore.framework/Runtimecore' (errno=2), '/System/Library/Frameworks/Runtimecore.framework/Runtimecore' (errno=2, not in dyld cache)
dyld config: DYLD_LIBRARY_PATH=/usr/lib/system/introspection DYLD_INSERT_LIBRARIES=/usr/lib/libBacktraceRecording.dylib:/usr/lib/libMainThreadChecker.dylib:/usr/lib/libRPAC.dylib:/Developer/Library/PrivateFrameworks/DTDDISupport.framework/libViewDebuggerSupport.dylib
cb2206
Found the cause. For some reason in the existing project the Runpath Search Path parameter in Build Settings was incorrect.
rolson_esri
Esri Alum
I do not have those same devices, but I have an iPhone 12 Pro and following the instructions on the Swift Package Manager page here I am able to build and deploy an app to the iPhone 12 Pro.  I did not do any manual steps for dragging and dropping into "Frameworks, Libraries and Embedded Content".  I am using Xcode 14.1.
The only difference from the instructions is that the instructions say to go to File > Swift Packages > Add Package Dependency.  But with Xcode 14.1, that is now just under File > Add Packages.
Please try with a brand new project, following the instructions here.
cb2206
Thanks for your reply.
Yes, I also just used the "add package" functionality in Xcode 14.1 but got that dyld error. I then tried the manual way to add the SDK described in the ArcGIS SDK how to get started page to see if that makes a difference but it didn't.
Yes, with a brand new project it works fine. There must be something in my existing project to which I need to add ArcGIS functionality which is causing the dyld but I'm out of ideas in which direction to search.
cb2206
