Crash on [AGSLocalTiledLayer localTiledLayerWithName:@"myMap"];
2096
07-30-2014 08:29 AM
gerritvan_der_Walt
When I try to instantiate an AGSLocalTileLayer with a tpk file, my app crashes.  It does work with the campus.tpk file in the demo app.  Is there a specific way to generate the tpk file so that it works with the 'ArcGIS-Runtime-SDK-iOS', '~> 10.2.3' pod?
See stack below.
2014-07-30 16:17:25.694 Schipol[3950:60b] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** -[__NSArrayM insertObject:atIndex:]: object cannot be nil'
*** First throw call stack:
  0   CoreFoundation                      0x04fb61e4 __exceptionPreprocess + 180
  1   libobjc.A.dylib                     0x04ba78e5 objc_exception_throw + 44
  2   CoreFoundation                      0x04f68abc -[__NSArrayM insertObject:atIndex:] + 844
  3   CoreFoundation                      0x04f68760 -[__NSArrayM addObject:] + 64
  4   Schipol                             0x00388fa8 -[AGSLayerInfo ags_updateLegendInfo:] + 824
  5   Schipol                             0x00388a4f -[AGSLayerInfo decodeWithJSON:] + 463
  6   Schipol                             0x0038886d -[AGSLayerInfo initWithJSON:] + 77
  7   Schipol                             0x002b4365 -[AGSLocalTiledLayer initWithPath:] + 1541
  8   Schipol                             0x002b3cab -[AGSLocalTiledLayer initWithName:] + 75
  9   Schipol                             0x001d39e8 -[MyMapViewController viewDidLoad] + 440
  10  UIKit                               0x0367433d -[UIViewController loadViewIfRequired] + 696
  11  UIKit                               0x0369a345 -[UINavigationController _layoutViewController:] + 39
  12  UIKit                               0x0369a85b -[UINavigationController _updateScrollViewFromViewController:toViewController:] + 235
  13  UIKit                               0x0369a953 -[UINavigationController _startTransition:fromViewController:toViewController:] + 78
  14  UIKit                               0x0369b8cc -[UINavigationController _startDeferredTransitionIfNeeded:] + 645
  15  UIKit                               0x0369c4e9 -[UINavigationController __viewWillLayoutSubviews] + 57
  16  UIKit                               0x037dd0d1 -[UILayoutContainerView layoutSubviews] + 213
  17  UIKit                               0x035c4964 -[UIView(CALayerDelegate) layoutSublayersOfLayer:] + 355
  18  libobjc.A.dylib                     0x04bb982b -[NSObject performSelector:withObject:] + 70
  19  QuartzCore                          0x0342c45a -[CALayer layoutSublayers] + 148
  20  QuartzCore                          0x03420244 _ZN2CA5Layer16layout_if_neededEPNS_11TransactionE + 380
  21  QuartzCore                          0x034200b0 _ZN2CA5Layer28layout_and_display_if_neededEPNS_11TransactionE + 26
  22  QuartzCore                          0x033867fa _ZN2CA7Context18commit_transactionEPNS_11TransactionE + 294
  23  QuartzCore                          0x03387b85 _ZN2CA11Transaction6commitEv + 393
  24  QuartzCore                          0x034455b0 +[CATransaction flush] + 52
  25  UIKit                               0x03572ce5 _afterCACommitHandler + 131
  26  CoreFoundation                      0x04f7e36e __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
  27  CoreFoundation                      0x04f7e2bf __CFRunLoopDoObservers + 399
  28  CoreFoundation                      0x04f5c254 __CFRunLoopRun + 1076
  29  CoreFoundation                      0x04f5b9d3 CFRunLoopRunSpecific + 467
  30  CoreFoundation                      0x04f5b7eb CFRunLoopRunInMode + 123
  31  GraphicsServices                    0x05a335ee GSEventRunModal + 192
  32  GraphicsServices                    0x05a3342b GSEventRun + 104
  33  UIKit                               0x03555f9b UIApplicationMain + 1225
  34  Schipol                             0x000040b2 main + 130
  35  libdyld.dylib                       0x054ff701 start + 1
  36  ???                                 0x00000001 0x0 + 1
libc++abi.dylib: terminating with uncaught exception of type NSException
DiveshGoyal
How did you generate the tpk file? If you used ArcMap, what version did you use?
The stack trace indicates there was some problem parsing the json in the tpk file, specifically the legend info. Would it be possible for you to share the tpk so I can take a look?
