Configure arcgis api for iOS on existing wikitude sample
1479
8
02-08-2013 12:57 AM
tarekhajar
hello,
Im trying to integrate arcgis with augmented reality, so i used an existing sample from the wikitude and tried to add the ArcGIS api.
I followed the same insructions provided by esri but im facing the problem below:
     when I add all_load to the other Linker flags im getting a linker error since it will load duplicate files from the   wikitude sdk so what i need is a way to use force_load to load the ArcGIS
please advice
thanks.
DiveshGoyal
Can you copy-paste the linker error description?
If you want to use force_load for ArcGIS, you should add this to the linker flag
 -force_load $HOME/Library/SDKs/ArcGIS/iOS/Versions/Current/libArcGIS.a
tarekhajar
attached are the linker flags
[ATTACH=CONFIG]21670[/ATTACH]
and the linker errors
[ATTACH=CONFIG]21671[/ATTACH]
Regarding the "-force_load $HOME/Library/SDKs/ArcGIS/iOS/Versions/Current/libArcGIS.a" it cannot be applied since im using
the ArcGIS API 10.1.1 and there is no file named libArcGIS.a, so can you please give me an alternative for this.
thanks again.
DiveshGoyal
That's fine. There doesn't need to be a file named libArcGIS.a
The lib prefix and the .a suffix are implied for a static library.
On disk you will find a static library called ArcGIS. If you need to refer to it, you need to use libArcGIS.a
(Disclaimer - I haven't tried this myself so I'm not 100% confident it'll work, but I have a feeling it might)
tarekhajar
Based on your advice i've tried the force_load as follow :
-force_load $HOME/Library/SDKs/ArcGIS/iOS/ArcGIS.framework/Versions/Current/ArcGIS
but it seems that it didnt work since when im using anything from the ArcGIS library ex AGSPoint the application crashes
and the xcode will be closed and shows an error. and this is beacuse im using a library typr without being loaded.
so i think that this is not working properly and there is still missing some configuration we need to add and i will be really thankfull if you help me accomplish this.
thanks you
tarekhajar
thanks you
DiveshGoyal
Can you try -force_load $HOME/Library/SDKs/ArcGIS/iOS/Versions/Current/libArcGIS.a
tarekhajar
I've tried
and
 -force_load $HOME/Library/SDKs/ArcGIS/iOS/ArcGIS.framework/Versions/Current/libArcGIS.a
both didnt work.
anyways if you found any work around for this please update.
thanks 🙂
HumzaAkhtar
Occasional Contributor II
I've tried
and
both didnt work.
thanks 🙂
Hi, In your screenshot you wrote "AcGIS". Can you retype it to ArcGIS and then remove -all_load and check please?
Regards
Humza
