AGSLocator, AGSLocatorDelegate, AGSAddressCandidate.. Tutorial
1893
03-30-2010 05:06 AM
ChanceYohman
AGSSpatialReference, & AGSPoint Tutorial Version 1.03.30.2010 (sorry, I use versioning numbers that make sense to me :])
Questions/Comments
1) This code is far from perfect. Memory leaks, etc. may be present. If you see something wrong, then please try to fix it and let me know.
2) I welcome someone to GUI-ify this. Right now, I'm traversing the object model. Either someone can wrap this with a GUI, or I'll do it later.
3) I've only been coding in Objective-C for 3 months now, but it seems the documentation should make it clear to beginners that init* methods can only be used on [AGS* alloc]. See code for examples in viewDidLoad in AGSAddressCandidateViewController.m, e.g. line 44.
4) Why does AGSPoint lack a spatial reference property? It would be helpful, if that or AGSLocator had a spatial reference. This way programmers would know the projection of coordinates coming back to them. Plus, IPoint in the ArcObjects model has a spatial reference property.
5) Why is there a difference in precision between the x & y properties of AGSPoint and its CGPoint property's x & y properties? Please see lines 75-79 of AGSAddressCandidateViewController.m .
6) I've brought this up before, but it looks like AGSAddressCandidate's attributes property has replaced the address property. Address's count is 0 for any AGSAddressCandidate I have seen, while attribute's count is non-zero. I take that back. The above is true for AGSAddressCandidates returned from locationsForAddress calls, while the reverse appears true for addressForLocation calls. Can anyone explain why there is a difference?
Thanks for reading and any responses you may have. 🙂
NimeshJarecha
[Nimesh] I�??m not clear about your question. You mean to ask why the spatial reference property of the returned location points (AGSPoint) is null or AGSPoint itself does not have a spatial reference property based on the doc (http://help.esri.com/en/ArcGIsmobile/9.4/apis/iPhone/Reference/Classes/AGSPoint.html)?
The AGSPoint does have a spatial reference property. If you change the code line (127 and 172) as following then you will see the location point�??s spatial reference information.
NSLog(@"Address Candidate @ (%f,%f,%@)",[location x], [location y], [location spatialReference]);
[Nimesh] We�??ll look into this.
[Nimesh] The Reverse Geocode  (addressForLocation) candidates does not have attributes property. You can verify it from the REST endpoint and REST documentation.
Reverse Geocode:
http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Address_NA/GeocodeServer/reverseGeoco...
Reverse Geocode REST API Doc:
http://tasks.arcgisonline.com/ArcGIS/SDK/REST/reverse.html
Hope this helps!
Regards,
Nimesh
ChanceYohman
[Chance] I agree it's there, but a few issues with it:
1) It's not explicitly documented:
http://help.arcgis.com/en/arcgismobile/10.0/apis/iphone/reference/Classes/AGSPoint.html
Implied by the initializers, but not written in as a property.
2) Sample output from line 127:
2010-04-05 10:50:13.754 AGSAddressCandidate[438:207] Address Candidate @ (-77.036696,38.897101,(null))
While the property is there, it's not being set.
Sample output from line 172:
2010-04-05 10:50:13.407 AGSAddressCandidate[438:207] Address Candidate @ (-149.687617,69.136652,AGSSpatialReference: wkid = 4326, wkt = null)
Better, but the well known type is still not being set.
NimeshJarecha
The documentation will be updated. The Address Candidate�??s spatial reference property issue is already been logged in our system.
Regards,
Nimesh
