About AGSPictureMarkerSymbol
1713
08-03-2018 05:37 AM
wangchao1
I have a question. I'm now adding a grafic with an  AGSPictureMarkerSymbol to a AGSSceneView. I give a AGSPoint to the grafic's geometry.when I finished it,the picture added to the map vertical. but what I want is a picture added horizontal。what should I do?
NimeshJarecha
You can either rotate the image as desired and then use in the AGSPictureMarkerSymbol or AGSPictureMarkerSymbol has a property `angle` which can set to desired value to change the orientation of the symbol.
Hope this helps!
Regards,
Nimesh
wangchao1
Maybe I made a wrong description. THe grafics with AGSPictureMarkerSymbolare all standing on the map,even I change the property "angle",it just changes the image's orientation,while it is still stand on the map.what I need is to lie it down, just like the grafic with AGSPictureMarkerSymbolarelie on the AGSMapView.What should I do?
NimeshJarecha
Can you please share the image you are using? Also, share screenshot of picture marker symbol on the map, how it looks currently and your expectations, how it should look?
wangchao1
here is how I make the grafic
and the image is just a png imag.
what it looks like uis here
and what i need is like this
just like the arrow at the center of the picture,I needthe picture parallel to the floor,what should I do.
NimeshJarecha
Are you using 2D or 3D map? Can you just send me the image you are using so I can create Picture Marker Symbol with it at my end?
Regards,
Nimesh
