Why dose mapview not show when i open the app whitout network?
1894
07-20-2021 01:57 AM
zhenghanzhang
Hello everyone :
     I created an offline app according to work requirements.It works good when i test with network.But when i cut the network,and open my app,it shows blank.Dose Arcgis supports without networking totally?
RamaChintapalli
The offline map should work without network as long as the layers within the map are accessible offline.
What layers does your offline map have. And what does the load status of Map & the layers suggest when you opened them offline.
Thanks
Rama
zhenghanzhang
thanks for answer! I just added basemap in my app.
load status: FAILED_TO_LOAD.
load exception:java.net.UnknownHostException: Unable to resolve host "basemaps-api.arcgis.com": No address associated with hostname.
RamaChintapalli
Looks like you are trying to access a connected layer  without network connection.
If you are specifically looking to work with an offline map that has a Basemap that works disconnected, then you can take one of the esri's Basemap offline and use it. The below samples do that by either downloading tile package from service or use an already downloaded tile package.
https://github.com/Esri/arcgis-runtime-samples-android/tree/main/java/generate-offline-map
https://github.com/Esri/arcgis-runtime-samples-android/tree/main/java/generate-offline-map-with-loca...
Thanks
Rama
zhenghanzhang
I Initialized the ArcGISMap by Basemap.Type.DARK_GRAY_CANVAS_VECTOR which needs network.I followed the samples you provided it works ,thanks a lot!
