The new LocationDisplayManager, Bugs or Not
6374
03-13-2014 07:49 AM
AlaaRasheed
Dears, Can anyone help me with the following scenario...
When I use LocationDisplayManager instead of the deprecated LocationService everything works fine but I am having side effects when I am trying to zoom programmatically to locations, the map will always zoom to current location after zooming to the provided location and if I do some panning on the map then try to zoom programmatically to any location the map then will zoom to completely different location which is not even my current location.
So I guess my question is, should I set some properties first to the LocationDisplayManager and why on earth changing location gots overridden ?!!!!!
this how I start the LocationDisplayManager
public void onStatusChanged(Object source, STATUS status) {
    if (source == _mapView && status == STATUS.INITIALIZED) {
_esriLS = _mapView.getLocationDisplayManager();
_esriLS.setAutoPanMode(AutoPanMode.OFF);
_esriLS.start();
AlaaRasheed
The walkaround provided in this post (http://forums.arcgis.com/threads/104596-Issues-related-to-animations-in-10.2.2-sdk) has solved my problem, I still think that there is something in the displaye manager that causing these side effects.
I have modify my zoom function putting the zoom line inside a runnable
public void zoomToPoint(double longitude, double latitude, boolean draw){
  final Point pnt = GeometryEngine.project(longitude, latitude, _mapView.getSpatialReference());
  if(draw)
   DrawMarker(pnt);
  final int res = draw ? 1 : 2;
  new Handler().postDelayed(new Runnable() {
   public void run() {
    _mapView.zoomToResolution(pnt, res);
  }, 1500);
GSauers
Hello Alaa, have you seen a memory leak with the new LocationDisplayManager? I am experiencing this issue to the point where my application crashes. The listener is not actually unregistered and the fragment remains open, so I have numerous instances of my fragment open.
Thanks.
DanO_Neill
Alaa Rasheed​ What version of the SDK were you using orginally?
G Sauers​ We will have a fix for that in the next release, but I am concerned that your app is crashing as the memory issue in 10.2.5 is ~2MB which should not crash your app.  I would be interested in more of what your app does to see if we can optimize it in other ways.
