Setting maximum extent?
2528
10-26-2013 09:21 PM
ThomasBinu
Is there a way to set the maximum extent of the map through the Android Esri API?
Thomas
DanO_Neill
The API does not provide a way to constrain the map extent.  You could implement this in a webmap or programmatically use the OnStatusChangedListener on the MapView to detect changes to the map and implement the logic to constrain the maps extent.
