Routes won't render to the screen
1963
02-19-2021 01:11 AM
OctavianSirbu
Hello,
I built a React Native component in Kotlin. I used a SimpleViewManager type of class to expose this component to React Native and I use it to render an esri map. The problem is I cannot use RouteTask properly for creating a route between 2 points on the map and I do not know where the problem is.
This is the function that I use:
private fun findRoute() {
        val routeTask = RouteTask(
                context,
                "https://route-api.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World"
        val routeParametersFuture = routeTask.createDefaultParametersAsync()
        routeParametersFuture.addDoneListener {
            try {
                val routeParameters = routeParametersFuture.get().apply {
                    isReturnDirections = true
                    setStops(routeStops)
                // get the route and display it
                val routeResultFuture = routeTask.solveRouteAsync(routeParameters)
                routeResultFuture.addDoneListener {
                        val result = routeResultFuture.get()
                        val routes = result.routes
                        if (routes.isNotEmpty()) {
                            val route = routes[0]
                            val shape = route.routeGeometry
                            val routeGraphic = Graphic(
                                    shape,
                                    SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, Color.BLUE, 2f)
                            graphicsOverlay.graphics.add(routeGraphic)
            } catch (e: Exception) {
                val error = "Error creating default route parameters: " + e.message
                Toast.makeText(context, error, Toast.LENGTH_LONG).show()
                Log.e(ArcGISViewMaps::class.simpleName, error)
and I use it in createViewInstance of the SimpleViewManager class that I mentioned before. See below:
override fun createViewInstance(reactContext: ThemedReactContext): MapView {
        val view = MapView(reactContext)
        ArcGISRuntimeEnvironment.setApiKey("myAPI")
        val map = ArcGISMap(BasemapStyle.ARCGIS_STREETS)
        view.map = map
        view.setViewpoint(Viewpoint(latitudeDefault, longitudeDefault, 72000.0))
        view.graphicsOverlays.add(graphicsOverlay)
        val pointDisplay1 = Point(longitudeDefault, latitudeDefault, SpatialReferences.getWgs84())
        addStop(Stop(pointDisplay1))
        val pointDisplay2 = Point(-6.2603,53.37,SpatialReferences.getWgs84())
        addStop(Stop(pointDisplay2))
        findRoute()
        return view
As a context for the RouteTask I use reactContext. I am passing that context from the package manager where I call this class to be exposed to React Native.
Finally, it shows an error that I catch and expose in React Native, the error says:
"Error creating default route parameters: com.esri.arcgisruntime.ArcGISRuntimeException: Invalid call.: Object failed to load, unable to execute task."
If you have any ideas regarding this issue, please do let me know as soon as possible.
Thank you!
RamaChintapalli
Does the `reactContext` provides the application or activity context?
Also were you able to perform route task operations outside of React Native setup, like running this tutorial.
https://developers.arcgis.com/android/route-and-directions/tutorials/find-a-route-and-directions/
Thanks
Rama
Jotded
Not sure if you'll receive this as this is an old post, but I'm having the exact same issue rn. If you have found a solution to this can you please share with me, thanks!
