Rotate the map view in the direction of driving
1144
09-25-2018 10:08 PM
AsifIsmail
Hello,
how do i rotate the mapview so that the driving path always become straight to the user(like in google maps)
in esri android and ios
RoseeleDahang
if its from current location probably can use sensor event? then
mMapView.setViewpointRotationAsync([currentHeading_from_sensor_event]);
Not sure if this is the scenario you are facing though..
CharlesLoftis
Checkout this sample. Look for AutoPanMode.Navigation in the code:
case 3:
    // Start Navigation Mode
    // This mode is best suited for in-vehicle navigation.
    Map.this.mLocationDisplay.setAutoPanMode(LocationDisplay.AutoPanMode.NAVIGATION);
    if (!Map.this.mLocationDisplay.isStarted())
        Map.this.mLocationDisplay.startAsync();
    break;
