Private CA Certificate
2361
08-04-2022 04:02 AM
AlessandroValra
Hi all, I'm facing a problem with an application that uses certificate with private certification authority.
I have an error when I try to instantiate a map with only basemap (no ESRI basemap but 1 service published on server where certificate is installed).
Domain specific configurations require that hostname aware checkServerTrusted(X509Certificate[], String, String) is used
I tried to apply workaround at this LINK , but it still doesn't work.
Anyone has the same problem? Could you help me?
TIA
Alder
2 Solutions
GuntherHeppner
@AlessandroValra
If I understand you correctly, you are connecting to a service that uses a certificate with an unknown CA or it is a self-signed certificate? Can you confirm this? What error are you getting when loading the map?
There are several options for dealing with untrusted server certificates:
1. Configure the service with a certificate from a known CA.
2. You can have your application trust your service by configuring your app's network security config.
3. You can set a DefaultAuthenticationChallengeHandler which will prompt the user to trust/not trust the service.
4. You can set a SelfSignedCertificateListener to trust your service without prompting users.
AlessandroValra
@GuntherHeppner , I applied your tip (4. You can set a SelfSignedCertificateListener to trust your service without prompting users) and it works 😉
Thank you again.
Alder
GuntherHeppner
@AlessandroValra
AlessandroValra
@GuntherHeppner, thank you for your reply
We use a self-signed certificate. The error returned is "Domain specific configurations require that hostname aware checkServerTrusted(X509Certificate[], String, String) is used"
TIA
Alder
AlessandroValra
Thank you again.
Alder
