obtain longitude and latitude in onSingleTap
2301
09-30-2012 01:31 AM
josejavier
for obtain point for the map from a coordenas, I use:   (center: longitude and latitude)
Point centerPt3 = (Point) GeometryEngine
    .project(center,SpatialReference.create(4326),mapa.getSpatialReference());
now I want the opposite, from point obtain coordinates :
      public void onSingleTap(float x, float y) {
         Point pnt = mapa.toMapPoint(x, y);
but Pnt is not correct  longitude and latitude
thanks
deleted-user-ATjHIWsdQYmT
I'm not sure if I am reading this correct, but can you simply project your point location in the reverse of what you are doing to center?
public void onSingleTap(float x, float y) {  Point pnt = (Point) GeometryEngine.project(mapa.toMapPoint(x, y),mapa.getSpatialReference(),SpatialReference.create(4326));
josejavier
OK, very thanks
