MPK for offline app
3538
11-27-2013 01:47 AM
teamIgal
Hello,
Is there a possibility to load MPK to a map in an offline application?
Ilona
EricBader
Honored Contributor
Hello,
Ilona
Hello Ilona,
Map Packages (MPKs) are not supported within an ArcGIS Android application. You can read Tile Packages (TPKs), however.
The MPK workflow is supported with the ArcGIS Runtime SDKs for Java, WPF and Qt.
I hope this is helpful.
teamIgal
Thank you Eric.
Is there a way to dynamically draw the TPK without creating the tiles before.
Something like client caching?
JasonKnisley
If you're referring to caching on the client while they are online so that they can later go offline, the TileCacheTask should be what you want, although it is tagged as being in beta as of the current 10.2.0 API.
I haven't used that yet so I'm not sure what hurdles you may find during implementation. Currently I create tpks from map caches and load them in their entirety onto a device for use as an ArcGISLocalTiledLayer.
