mapView is blank when added to a layout
3781
03-12-2013 06:46 AM
SethSeligman
When I have a mapView that is already defined in a layout and set the view with the following code, everything works fine:
map = (MITMapView)findViewById(getMapViewID());
However, if I tried to add a mapView dynamically to a linear layout using the addView method, the mapView appears blank (black or grey). If there any way to dynamically add mapviews to a layout?
SriramV
Iam able to add the MapView dynamically. Here's the code snippet:
Java Code:
  map = new MapView(this);
  ((LinearLayout)findViewById(R.id.contentLayout)).addView(map, 0,new LinearLayout.LayoutParams(LayoutParams.FILL_PARENT,  LayoutParams.FILL_PARENT));
  map.setExtent(new Envelope(-19332033.11, -3516.27, -1720941.80, 11737211.28));
XML:
    <LinearLayout
        android:id="@+id/contentLayout"
        android:layout_width="fill_parent"
        android:layout_height="fill_parent"
        android:orientation="vertical" />
Do let me know if you meant something else.
V. Sriram
