Feature Layer not displaying?
2872
04-23-2013 12:33 AM
TrevorHart1
Im following the MyWater sample.
In my mapview I've added the feature layer as per the sample
ie http://mobilesampleserver.arcgisonline.com/ArcGIS/rest/services/DemoData/incidents_service/FeatureSe...
But its not displaying...
Its definitely loading since if I add the feature layer first the extent of the map is the extent of the Feature Layer.
Is there anything else I need to do get it to display on the map.
TrevorHart1
Still cant get it to display. Its definitely loaded as if I call getDisplayField() I get a string returned of "description" which is consistent with the service being used.
TrevorHart1
TrevorHart1
Wow, now its even more bizarre.
Exact same code on Galaxy Tab (Android 4.0.4) and water incidents feature layer displays perfectly.
Same code on S2 (Android 4.0.3) and water incidents feature layer does not display.
