I'm loading a map but it is displayed in gray
1021
03-01-2023 07:06 AM
stiven
when I load the map it appears gray but the layers or points are displayed fine:
 the sdk that I currently have is 30  and this is the version of Sdk arcgis
api 'com.esri.arcgisruntime:arcgis-android:100.8.0'
This is the step by step of the methods I use:
private void startMap(){
        loadMap();
        locationDisplayManager = base_mapView.getLocationDisplay();
        if(!startGraphicsOverlay){
            base_mapView.getGraphicsOverlays().add(mGraphicsOverlay);
            startGraphicsOverlay = true;
        locationDisplayManager.stop();
private void loadMap() {
        ArcGISRuntimeEnvironment.setLicense(Constants.CUSTOMER_ID_ARCGIS);
        base_mapView = new MapView(this);
        baseMap_frameLayoutArcgisMap.addView(base_mapView);
        createPortalItem();
        mCallout = base_mapView.getCallout();
        startListeners();
private void createPortalItem(){
        if (base_mapView != null) {
            portal = new Portal(urlBase, false);
            portal.loadAsync();
            portal.addDoneLoadingListener(() -> {
                ArcGISRuntimeEnvironment.setLicense(Constants.ARCGIS_LICENSEINFO);
            portalItem = new PortalItem(portal, id);
            map = new ArcGISMap(portalItem);
        base_mapView.setMap(map);
PriyankaRupani
Just curious, if the map displays differently in any other
version?
