How to setFullExtent
1874
11-28-2012 05:25 PM
dixonkwan1
Dear all,
   I have a basic question..how to set the full extent of the layer or mapview?
dixonkwan1
when i use mLayer.getFullExtent() (the mLayer is one of the mapView's layer), but it returns null, so is it possible to setFullExtent to a layer?
deleted-user-ATjHIWsdQYmT
You'll have to be sure that mLayer is initialized.
  mLayer.setOnStatusChangedListener(new OnStatusChangedListener(){
     private static final long serialVersionUID = 1L;
   public void onStatusChanged(Object source, STATUS status){
     if (OnStatusChangedListener.STATUS.INITIALIZED == status) {
            mapView.setExtent(mLayer.getFullExtent());
         else if(OnStatusChangedListener.STATUS.INITIALIZATION_FAILED == status){
     dialog.dismiss();
     Toast toast = Toast.makeText(getApplicationContext(), "Failed to load Layer",Toast.LENGTH_SHORT);
     toast.setGravity(Gravity.BOTTOM, 0, 0);
     toast.show();
dixonkwan1
Thanks for the reply, I have confirmed that the layer is initialized and added into mapView, but the getFullExtent is still returns null,
btw, I found only the first layer of the mapView has FullExtent, other return null.
Here's what the API documentation says about getFullExtent();
getFullExtent
public Envelope getFullExtent()
Returns the full extent of the layer. Returns NULL if the layer does not have a full extent.
Returns:
an Envelope
objectSince:1.0
Maybe your layer does not have a full extent?
If you look at the REST endpoint of your layer, does it have a Full Extent defined?
