How to configure search widget in ArcGIS Runtime SDK for Android
3251
01-03-2016 02:56 AM
FatmaŞenol
Dear Geonet Members,
I searched posts in Geonet to find the solution but I just couldn't find what I was looking for.
Could you please kindly suggest a document or share your suggestions on how to configure
the search widget ? I want to limit the search only to the specific layers. Thank you.
Regards
FatmaŞenol
Hello,
I'm really sorry for not responding your message earlier.
Your suggestions worked for me Thank you
Best Regards
- Saygin
AlexanderNohe1
Honored Contributor
Hello,
I believe that you would want to create your own search bar and when you press the search button you would want to populate the find parameters(FindParameters | ArcGIS Android 10.2.7 API ) with the text that was entered.  Then you would want to fire off the FindTask(FindTask | ArcGIS Android 10.2.7 API ) Asynchronously and when it has completed, use the FindResult to display the results ( FindResult | ArcGIS Android 10.2.7 API )
Hope this helps!
FatmaŞenol
Hello,
Best Regards
- Saygin
