Heat Map
3243
02-29-2012 09:53 AM
AnthonyC
How would i go about implementing a heat map on the ArcGIS SDK for Android?
I can draw geometry objects using a GraphicsLayer, but i have seen no way of drawing rasters. I was thinking possibly extending the base Layer class, but I see no render or draw method that would allow me to manually render the heat map.
Any suggestions?
GSauers
I know this is an old topic, but does any one have any suggestions for getting starting with heat maps on Android?
I already have a solid mapping application using ArcGIS, but I want to add heat maps to it.
Thank you for any help.
