DefaultOAuthIntentReceiver OAuth Redirect URI
2556
6
01-26-2024 05:53 AM
NathanMeade
From the sample code, the redirect URI is as follows:
"authenticate-with-oauth"
Example:
<activity
android:name="com.esri.arcgisruntime.security.DefaultOAuthIntentReceiver"
android:exported="true"
android:launchMode="singleTask">
<intent-filter>
<action android:name="android.intent.action.VIEW" />
<category android:name="android.intent.category.DEFAULT" />
<category android:name="android.intent.category.BROWSABLE" />
<data
android:host="@string/oauth_redirect_host"
android:scheme="@string/oauth_redirect_uri" />
</intent-filter>
</activity>
Where "oauth_redirect_host is "auth" and "oauth_redirect_uri" is "authenticate-with-oauth". When used properly in the sample code as shown in: https://developers.arcgis.com/android/java/sample-code/authenticate-with-oauth/
This works as expected. Here's my question though, why does any other redirect URI not navigate back to the Android app? When I use a different redirect URI I either see an error displayed before I can even log in or I just continuously see the login prompt after logging in. I've tried multiple different configurations without success. I thought this post would help but I still observe the same issue: https://community.esri.com/t5/arcgis-runtime-sdk-for-android-questions/android-oauth-what-should-i-u...
RamaChintapalli
When we register your app for OAuth, we have to specify the re-directURI. For a given ClientID, only the registered re-directURIs are allowed. For the sample, the redirectURI allowed is `authenticate-with-oauth://auth`. You need to register your own app.
Thanks
Rama
NathanMeade
Yes, I am already doing this. I am registering different redirect URIs to my ESRI Application for the given client id. When I reference any redirect URI I already have set that isn't  `authenticate-with-oauth://auth` then I just get the infinite loop of being prompted to login. Why is this the only redirect URI that actually navigates back to the app?
RamaChintapalli
Can you share the other re-directURIs format that you specified at the time of registering the app? The browsers expect it to be <my-custom-app-scheme>://<my-custom-app-host>. The semi-colon with two forward slashes is required
Thanks
Rama
NathanMeade
The main one that I was using was "MobileMap://auth". I had this set as a redirect URI for my ESRI application and also was in the Android code as well (DefaultOAuthIntentReceiver in AndroidManifest.xml and OAuthConfiguration in MainActivity).
RamaChintapalli
The re-direct URI seems fine. Would it be possible to share your repro code (using a temporary account)  via a direct message  or provide network logs via direct message or debug your app through our support?
NathanMeade
Hey Rama, I appreciate your help on this. I believe that I do actually have it working now. I'm not allowed to share the source code but in case I end up having issues again with this I could pursue one of those other two options.
