Custom Featurelayer
1306
03-31-2014 02:59 AM
mavenmaven
Hi:
We have some POIs which we want to add them to the maps as a kind of Layer.
In face, this is similar to ArcGISFeatureLayer, while the server does not hold a ArcgisFeatureService but a common web service, we can parse the data ourselves.
I wonder if this is possible?
ShellyGill1
Perhaps you don't really need a custom Layer, as the GraphicsLayer might do everything you need. Take a look at this sample that converts a CSV file to a GraphicsLayer in a map by connecting to a URL, parsing the CSV file that contains coordinates and attributes into Graphic objects, adds these Graphics to a GraphicsLayer and adds the layer to a map:
http://developers.arcgis.com/android/sample-code/addcsv-file/
Whether this is suitable or not depends on what kind of functionality you need in the layer really - you can add and remove graphics, change graphics, change visibility, and get graphics based on screen coordinates. See the JavaDoc for more info:
https://developers.arcgis.com/android/api-reference/reference/com/esri/android/map/GraphicsLayer.htm...
mavenmaven
That's not what I want.
First, it load all the csv data one time, but we have too many records, it is not a good idea to load all of them once.
Second, load all the record out side the viewport of the mapview is a waste of network and memory.
The ArcgisFeatureLayer seems load features on demand. Is it possible?
