Adding a Graphic freezes
2471
01-22-2014 09:26 AM
RudolfKopriva1
We have a custom grid, which is a GraphicsLayer. It updates every time the map panning ends or zooming ends. We remove old graphics and add a new collection. It works 5 or 6 times, but then it suddenly freezes inside the addGraphic method and the map freezes as well. It was working in 10.1.1 SDK, but it's freezing in 10.2. Looks almost like a deadlock in nativeAddGraphic method. Do you have any ideas what could be causing it and how to avoid this issue?
RudolfKopriva1
I created a project based on the SimpleMap sample to demonstrate the issue. Attached is a source of the Activity.
The problem happens when I add 2 tiled layers and one graphic layer, it seems to work with single tiled layer.
Try to zoom or pan a few times and you should see the graphic layer will not render fully. The map will freeze and stops rendering at all.
I was testing it on Samsung Galaxy S3 and Samsung Galaxy Tab 3 devices.
Thanks
