Location Referencing license for server?
2676
08-15-2022 06:22 PM
GraemeBrowning_Aurizon
In ArcGIS Pro 3.0.1 I have a Location Referencing license that I've been using successfully to create and edit an LRS dataset and line network in a File Geodatabase.
Now I'm trying to use Migrate an LRS from a file geodatabase to a multiuser geodatabase—ArcGIS Pro | Documentation to start editing my LRS in an Enterprise Geodatabase via feature services.  However, as soon as I look for my enterprise Location Referencing dataset I get that "The Location Referencing dataset was not found."
Is there such a thing as a Location Referencing license on the server that needs to be authorized before I can properly see a Location Referencing dataset stored there?
AyanPalit
@GraemeBrowning_Aurizon The Location Referencing Server extension must be licensed to publish services with LRS capability.  There is no install on the Server side but you need to activate the server-ext license. The Event Editor web app is a separate install. However, you should see the LRS Hierarchy using a direct connect to the Enterprise GDB (just Pro Location Referencing  license required).
Ayan Palit | Principal Consultant Esri
AyanPalit
Thanks @AyanPalit
I found out about the "Location Referencing Server Pipeline_Roads" authorization (which we do have in place) just before I saw your reply.
- Graeme
