I'm experiencing a non-monotonic route issue in R&H
3983
14
01-09-2020 08:16 AM
NicoleHanson1
I did a realignment this past fall and have since learned that the section of centerline ended up generating a monotonic route.  I've called support and what they talked me through doing hasn't helped.  I'm about to just nuke the route and draw again...  but I'm afraid it'll happen still.  I've tried recreating the centerline in that spot, but that didn't work either.  Tried Generating Routes again, and that didn't work.  I'm out of ideas and really need to get this solved/fixed asap.
NicoleHanson1
I didn't know I could do that!
<?xml version="1.0"?>
<RouteEditModel xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" SchemaVersion="2">
<RouteEditActivity xsi:type="RealignRouteInfo" LrsId="6e9f58e4-3890-45c1-97ab-4898ff908057" NetworkId="2" RouteId="01010DIN084" NewRouteId="01010DIN084" OperationTime="2019-12-01T00:00:00" FirstM="-0" LastM="275.656751" IsPerformDownstreamCalibration="true" DoNotApplyEventBehaviors="false" IsFirstPointTouches="true" IsLastPointTouches="false">
<RealignedPortion OldFromMeasure="220.9100892" OldToMeasure="222.1392768" NewFromMeasure="220.9100892" NewToMeasure="222.0256467" />
<DownStreamPortion OldFromMeasure="222.1392768" OldToMeasure="275.656751" NewFromMeasure="220.9100892" NewToMeasure="275.5431209" />
<UpStreamPortion OldFromMeasure="0" OldToMeasure="220.9100892" NewFromMeasure="0" NewToMeasure="220.9100892" />
</RouteEditActivity>
</RouteEditModel>
NicoleHanson1
That's the problem, it somehow has two measures - the realigned portion and the downstream....  I don't remember agreeing to that..  So how would I go about fixing it?
RyanKoschatzky
With a copy/paste it could be a case of dirty geometry causing the issue. We try to instruct our editors to create the geometry themselves to cut down on any potential problems.
NicoleHanson1
I could see that if I copied just from cad into centerline (and if other places were having similar issues).  But I use the redline to edit and clean up all geometries so that I can avoid issues.
NicoleHanson1
So I tried to use Delete Routes so that I could just recreate the offending route.  I couldn’t get it to work on the route.
And I got told of another route that had NaN measures.  I used it on that route with no issues (Delete Routes) and recreated it which fixed the NaN measures.  It had calibration points that were correct.
Seeing those points, I went and checked for any calibration points along the 01010DIN084 spot that I was having issues and noticed at least half a dozen or so that were not in any real order for the measures – think that’s what was causing my issues and ended up removing those calibration points only (left all the others on that route alone).  After rec & posting and having the business users look at their data at that spot, it looks like it’s been resolved.
