ArcGIS Pro can't edit an LRS network in SQL Server?
2327
04-23-2020 02:22 AM
JonathanSloan1
I've been able to create an LRS in a file Geodatabase and succesfully create and edit a network dataset in ArcGIS Pro 2.5.
When I import this LRS from the file Geodatabase into SQL Server everything looks OK however ArcGIS Pro no longer recognises the network dataset and I can't edit it with the LRS tools. The LRS tools have an alert requesting that I add a network layer.
When I explore the database connection in Arc Catalog I can see the LRS and I can expand this to see the Network dataset and the event datasets I created under the network.
I tried to share the LRS from ArcGIS Pro 2.5 to ArcGIS Enterprise 10.6.1 and this fails with the following error message found deep down in the log files:
Unable to instantiate class for xml schema type: LocationReferencingDatasetMembership
Can anyone provide some guidance on where I may have gone wrong?
Jonathan
NathanEasley
Hi Jonathan,
When you move into ArcGIS Pro to use Roads and Highways, there are differences between how your data needs to be configured vs ArcMap.
The major differences are below:
-Roads and Highways is service based within ArcGIS Pro, which requires you to branch version your data and utilize a service for editing
-Your LRS feature classes (minimum schema, networks, events, intersections) need to be within a single feature dataset
-To support branch versioning, all your LRS feature classes and tables need to have Editor Tracking and GlobalIDs enabled
-Once your data is within a feature dataset with editor tracking and globalIDs present, you need to run the Modify LRS geoprocessing tool to "upgrade" your LRS to work within ArcGIS Pro.
Nathan
Esri Roads and Highways team
NathanEasley
Hi Jonathan,
Nathan
bbieb
It looks like current RH users will need to change their enterprise geodatabases significantly to accommodate the switch to Pro.  We would basically need to move all of our events (70+ tables) into a single feature dataset?  Is this correct?
brian
brian
NathanEasley
Hi Brian,
That is correct.  At Pro 2.5, the Roads and Highways minimum schema items (centerline, calibration points, redline) need to be in a feature dataset.  At Pro 2.6, we'll complete the controller dataset and LRS container in the catalog window which will require all LRS feature classes (minimum schema, networks, events, intersections) in a feature dataset.  We'll continue to document the requirements for the Roads and Highways information model here LRS data model—ArcGIS Roads and Highways for ArcGIS Pro User Help | Documentation
Nathan
JonathanSloan1
Nathan,
I didn't have my network inside the feature dataset.
Thanks for you help.
Jonathan
