Hello,
I've been able to create an LRS in a file Geodatabase and succesfully create and edit a network dataset in ArcGIS Pro 2.5.
When I import this LRS from the file Geodatabase into SQL Server everything looks OK however ArcGIS Pro no longer recognises the network dataset and I can't edit it with the LRS tools. The LRS tools have an alert requesting that I add a network layer.
When I explore the database connection in Arc Catalog I can see the LRS and I can expand this to see the Network dataset and the event datasets I created under the network.
I tried to share the LRS from ArcGIS Pro 2.5 to ArcGIS Enterprise 10.6.1 and this fails with the following error message found deep down in the log files:
Unable to instantiate class for xml schema type: LocationReferencingDatasetMembership
Can anyone provide some guidance on where I may have gone wrong?
Thanks
Jonathan
