[User Error] Successful UpdateFeature REST request results in the feature being deleted from the target (2 part unexpected action)
1796
01-23-2025 10:51 AM
AgLaCo
Edit: Yours truly is a big dumb dumb, and had a filter on the MapViewer instance I was using, which is also applicable to the Field Maps map that I was testing this on. So, sure enough, every map I checked, had the feature removed. But, all the data was still there, loading it into ArcPro showed that. Heck, it looks like the values I thought were bad, actually don't matter to the converter, it can handle all sorts of numerical data.
Big W for ESRI, Big L for AgLaCo.
Original Post:
Discovered the bug on Monday, I have no idea how long it has been happening before that. Caught it in the wild yesterday, so I think I have some guesses as to how it is happening, but even if I'm doing something wrong (Which I am, I will get more into that), that shouldn't cause the the feature to be deleted, it should just cause the update to fail. I will go into more detail to describe each problem.
Problem one: Update Features is removing features.
Given that there is a DeleteFeatures REST method, it is my understanding that Update Features should not remove features, it should only change them. I updated a feature yesterday, receiving the following updateResults response:
 "updateResults":[
    "objectId":34,
    "uniqueId":34,
    "globalId":"0bdc2adb-0475-40f4-b6b1-61e11f0abacd",
    "success":true
 This response communicates that the object was successfully changed, and indeed, when I check the layer in ArcGIS Online, I can see that it was changed... by being completely removed. Notice in the following image the absence of OBJECTID 34 (It is sorted by lowest to highest number).
This on its own is a big problem, but there is a second part to this problem, given the data that I presented to the REST endpoint that might have caused this problem.
Problem 2: Faulty data did not result in a failed update.
I know for a fact that some of the data passed in was faulty. Unfortunately, I do not have all of it logged since the application I am building is still new and is missing logging for some parts(And I never expected a failure like this on the ESRI side of things), but I was able to run the last update again and get a request that is at least similar to what it looked like yesterday.
features=[
 "attributes":{
  "OBJECTID":34.0,
  "WEEDID_HISTORICAL":"39-KG",
  "LEGAL_LAND_DESCRIPTION":"",
  "ROLL_NUMBERS":"",
  "OWNERSHIP":"Private",
  "CASE_STATUS":"Retired",
  "PRIORITY":"(1) Low",
  "WEED1":"Scentless Chamomile",
  "ACREAGE":0.157932089313962,
  "WEED_LOCATION":"this is a testin",
  "ACTION":"Compliant",
  "SYNOPSIS":"we are still testing ",
  "LANDOWNERS":"joe joe",
  "NOTES":"July 17/13: On July 15/13 I noticed a large patch of SC in the ditch and along the fenceline. It was raining quite hard so I wrote it down and \r\n\r\ncame back on July 16/13 and picked a large bag. Keep an eye on it. AGLACO -AGLACO\r\n\r\nJune 20,2016: There has been no SC for the past couple years, Case closed. AGLACO",
  "GlobalID":"0bdc2adb-0475-40f4-b6b1-61e11f0abacd",
  "Shape__Area":1727.9140625,
  "Shape__Length":204.00752354538685,
  "CreationDate":1.712944949133E12,
  "Creator":"AgLaCo",
  "EditDate":1737653752023,
  "Editor":""
 "geometry":{Geometry ommitted from this sample}
&rollbackOnFailure=true
&f=json
In the above example, there are several faulty data submissions.
  • OBJECTID - This field is your standard run of the mill OBJECTID field, and is not a float. Therefore, obviously wrong (But Arc seems to have no problem tracking this value as a float in other situations, this did take a while to notice after-all).
  • CreationDate - This field is the standard Edit Tracking Enabled CreationDate field. This value is supposed to be a long, but in the above example, you can see it has converted into a double written down as a power of 10.
    • This is obviously wrong, and this alone should result in the update failing, but the "update" was successful regardless.
  • There are fields listed that probably shouldn't be there: Shape_Area, Shape_Length, CreationDate, Creator. If there are fields that shouldn't be there, they should either be only read, or throw an error and fail to update the Feature.
While Javascript doesn't usually care (and indeed, the server even found the right Feature before it deleted it) about floating point numbers vs other ones, I can see a problem with the ArcGIS backbone trying to assign a float value to an int column.
To add more detail, it came to my attention that a library my program uses for reading and writing JSON was writing int and long values to doubles. This didn't seem to cause problems a lot of the time, so I didn't notice at first, but sure enough, points were being removed when I updated them with UpdateFeatures on the Feature Server.
Unfortunately that is all of the information I can provide at this moment on this bug, but I have had it happen to me multiple times before now with the same Layer. I am making a tool that converts Sharepoint Document Libraries to Arc Layers and vise versa, and I already completed the part that copies all the information out of Arc and into Sharepoint, which is how I noticed that features are missing on the original dataset. When checking if the update went through (I was looking for no change or change in a single field), the corresponding Arc field was instead completely gone.
AgLaCo
Not a bug, just a faulty keyboard-agent.
JesseCloutier
Esri Community Manager
Hi @AgLaCo, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
AgLaCo
I should note for any observers, I have already registered a case for this issue. That said, I am glad to know that is the proper way to forward things in the future. I was not aware of that before this situation.
JesseCloutier
We don't prohibit sharing details about bugs or potential bugs here in Esri Community—there are some cases where other users have helpful knowledge to share. We just want to make sure that our members don't skip over the official reporting process to post about bugs here instead and expect that both routes serve the same purpose. If you do share information about potential bugs in the future, it can be helpful to include up front that you've already submitted a case so that our teams and other members know. All the best!
Jesse Cloutier
AgLaCo
