Unable to get distinct values in the table: Get error message "Error performing query operation" most of times
1039
03-10-2022 04:01 AM
RomanBoros
We are using ArcGIS REST Services (Version- 10.71), for querying distinct values in the table, however, most of the time our query return error: “Error performing query operation”  with a 500 error code.
In the table, there is a total of 330094 records, of which only 24420 should be returned with a given where clause (Play='Permian Delaware Tight, US').
Moreover, there are only 201 distinct values in the given field('operator') when aforementioned where clause is applied.
Mainly my query contains following constraints:
where = Play='Permian Delaware Tight, US'
outFields = 'operator'
returnGeometry = false
returnDistinctValues = true  (optional, even if we set this to false, we're still getting the issue)
returnCountOnly = true
Overall request URL:
{our RestURL}
/query?where=Play+%3d+%27Permian+Delaware+Tight%2c+US%27&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=
&spatialRel=esriSpatialRelIntersects&distance=&units=esriSRUnit_Foot&relationParam=&outFields=operator
&returnGeometry=false&maxAllowableOffset=&geometryPrecision=&outSR=&having=&gdbVersion=&historicMoment=
&returnDistinctValues=true&returnIdsOnly=false&returnCountOnly=True&returnExtentOnly=false&orderByFields=
&groupByFieldsForStatistics=&outStatistics=&returnZ=false&returnM=false&multipatchOption=xyFootprint&resultOffset=
&resultRecordCount=&returnTrueCurves=false&returnExceededLimitFeatures=false&quantizationParameters=
&returnCentroid=false&sqlFormat=none&resultType=none&featureEncoding=esriDefault&f=pjson
I believe this is a simple query and should not throw exceptions. Please let me know if I’m missing anything here.
Layer settings are as follows: (which I believe are correct for a given query to run)
Supports Advanced Queries: true
Advanced Query Capabilities:
Supports Statistics: true
Supports OrderBy: true
Supports Distinct: true
Supports Pagination: true
Supports TrueCurve: true
Supports Returning Query Extent: true
Supports Query With Distance: true
Supports Sql Expression: true
Supports Query With ResultType: true
Supports Returning Geometry Centroid: false
Supports Binning LOD: false
Supports Query With LOD Spatial Reference: false
Thanks for any help in advance.
