suggest REST api does not return common name
2732
08-11-2025 05:29 PM
hoogw
when i search "target" it suggest return correctly with all common name + address.
see here
when I search address,  "5731 bickett st", it should show target, however, suggest only show address, missing common name "target"
This 5731 actually has 10 stores, I want suggest to show all 10 stores with same address,
However, suggest show 0 store, only show 1 address. which is wrong.
hoogw
find address candidate should show all 10 stores with same address 5731 bickett ave,
however, it only return 1 candidate without offCommonName.
Noah-Sager
You'll want to use the category value for that sort of filtering, here is the doc:
https://developers.arcgis.com/rest/geocode/category-filtering/
And/Or, you might be more interested in the places service than in world geocoding for this use case:
https://www.esri.com/en-us/arcgis/products/arcgis-location-platform/services/places
hoogw
Can you show how to use category ?
Are you sure category can fix it? prove your suggestion here, I will accept your idea as solution.
Without evidence, by just saying use your mouth, I can not accept as solution.
It is just saying without any evidence to prove it.
