Spatial reference impact on performance
1216
01-25-2012 08:08 AM
ShaningYu
Honored Contributor
Scenario Description:
1) Source feature layers' S.R. = 4326
2) In the mxd, set the frame's S.R. as 102100.
3) Load the source feature layers.
4) Publish the mxd as a map service.
5) Add the layers in the published map service as dynamic layers, which overlay on ESRI's basemaps.
Qestion:  Will this impact the performance?
TanuHoque
another factor that I forgot to mention is the number of simultaneous users using your service.
TanuHoque
Yes.
Depending on number of features and the complexity of features, you may see noticeable difference in the performance.
In your case, every export request will project features on-the-fly which is expensive operation.
If you can, we recommend to project your FeatureClass to the destination SRS (i.e. 100210) and publish that as a mapservice.
TanuHoque
