Serving Up Multiple Data Frames In An MSD With One Service Using ArcGIS Server 10 SP1
3738
08-22-2011 10:36 PM
PercyJackson
Hi everyone
I am looking for some urgent help.
I have built a map with multiple data frames in one MSD.
I have successfully setup my web service and my web application through ArcGIS Server Manager.
Within the setup of my web application I was able to add and setup my multiple data frames in one service.
My problem now is that in http://myserver/ArcGIS/rest/services/my folder/MapServer I can only see one data frame(my active data frame)
Is there a way to see all my data frames in my rest services folder?
My developers is using Silverlight to develop our applications, and they can`t go further if the other data frames is not visible in my rest services.
My developers are new to ArcGIS and any help would be appreciated.
Thanks in advance.
SrinivasVinnakota
REST only supports default map (active data frame). If you would like to use non-default map then you would need to access your map service as a SOAP service.
Alternately, you could create multiple map documents with one data frame each and publish multiple map services. Have logic in your application to switch between these map services.
PercyJackson
Hi Srinivas.
Thank you very much for the reply.
I will let my Developers know.
Regards,
