Rest ArcGIS Services Directory is empty and no services are listed
4449
04-19-2012 12:03 AM
DöringSebastian
i have ArcGIS Server10 and two running mapservices. But nothing is listed in my Browser under rest?!
http://<host>/ArcGIS/rest/services/   -> is empty
in the rootfolder of my server is the rest folder with the css and two config files.
Any Ideas what i forgot?
Thanks for your time,
nicogis
-Have you enabled security for service?
-Have you details in log rest?
DöringSebastian
hi,
thx for the reply!
no, there is no log file created yet.
but it seems that my problem is not the rest-api!
Because i can connect via ArcCatalog to manage and create my mapservices. But when i try to connect as user i get these massage:
"Unable to connect... No resource could be found at that address"
thanks,
Sebastian
DöringSebastian
now i solved my problem with the rest api. the problem was that the browser auto correct the address from http... to https..., which is not working
in my case.
But the connection via arccatalog as user over internet isn't working.
karthik_BharadwajT
im facing similar issues where The services are running as seen in ARC Catalog, but the rest directory is empty. Please let me know if some one has got a solution to it. Thanks
YooHubert
Sorry for reviving this topic, but I am running into a similar issue with Server 11.1 where I can hit the REST endpoint using Postman, but not with my web application. I get a 200 response back, but its an empty list of services. Any help would be appreciated!
