QueryTask Error on Joined Layer in Map Service
3526
02-09-2011 01:53 PM
ScottDavis
I have a map service with a layer that is joined to an external SDE database. When I try to perform a query through the services directory I get the error message, "Unable to perform query. Please check your parameters." The server logs two error messages, "General GeoDatabase Error." & "Method failed.HRESULT = 0x80070057 : The parameter is incorrect. ."
Here is my test:
http://172.16.17.48/ArcGIS/rest/services/OilGasMining/MapServer/0/query?text=&geometry=&geometryType...
Just wondering if anyone else has had this problem.
RaviNarayanan
Are you able to execute an identify on this layer and get the fields from the joined table?
From the error messages, this sounds like a failure in the geodatabase. Please contact ESRI Support and submit a request to investigate this further.
RaviNarayanan
Scott,
Please see http://resources.arcgis.com/content/nimbus-bug?bugID=TklNMDQ1MjU5 for information on  related bug report. This is marked as non reproduced in 10.0.
JacobLesser
I know this is an old post.  I got the same error with ArcGIS Server 10 and PostgreSQL when joining a feature class to an SDE table.  The solution turned out to be that when doing a join, the column names are prepended with the original table names, so my columns look like table1.field1 and table2.field2 instead of just field1 and field2.  In the case of postgresql, I actually needed to append my database and schema names, so the outfields look like database.schema.table1.field1, etc.
Just wanted to share in case anybody else stumbles on this post like I did.
