Order of fields in mxd not the same as in REST
3027
06-28-2011 12:56 PM
MatthewLewin
If reorder the fields in a layer in an mxd and then publish to AGS, the order of the fields in the corresponding REST url are not the same...they seem to default to the order of the fields as defined by the underlying datasource (in this case SDE).  Is this known behaviour?  Is there any way to define the order of the fields in a layer in AGS?
MartinErglis
Have the same situation
SrinivasVinnakota
This is a known behavior. Currently there is no way to specify the order of the fields returned by mapServer.
RaviNarayanan
One option is to specify the order of fields in the outfields
for example:
ORDER OF FIELD: CNTY_FIPS,STATE_FIPS
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0/...
ORDER OF FIELD: STATE_FIPS,CNTY_FIPS
