Landsat8_Pansharpened image export
1214
02-01-2024 01:54 AM
SiddharthSrivastava
Hi all,
I'm trying to download some samples of Landsat 8 pansharpened images using this REST API endpoint - https://landsat2.arcgis.com/arcgis/rest/services/Landsat8_PanSharpened/ImageServer/1005308/image
The params which work -
- Bounding Box: 219000.0, -126300.0, 234000.0, -111300.0
- Bounding Box Spatial Reference: 32634
- Image Size: 100, 100
- Image Format: tiff
- Interpolation: RSP_BilinearInterpolation
- Format: Image
The above params give a pixel size of 150m which is ok. But then when I change Image Size to 1000, 1000 for a desired pixel size of 15m, I get error - "Unable to complete operation. Not implemented"
Is there some other parameter I'm missing? Some guidance on this would be appreciated. I tried looking around for information on the same but could not find anything.
Siddharth
SiddharthSrivastava
Ok solved my own question. Putting it out there in case anyone else stumbles across this issue - I was using Pixel Type: F32 whereas it S16 works.
SiddharthSrivastava
