GP service not listed in ArcGIS Services Directory
1191
05-18-2011 04:43 AM
JarkkoKuoppamäki
I'm running ArcGIS Server 10 Advanced Enterprise for Java, SP1 installed (soon SP2), on Red Hat Linux. I have several map services and a geometry service up and running successfully.
I've published a geoprocessing task, it appears just fine on the services list in ArcGIS Manager [1]: it is started and running, and the wdsl link [2] works. The ArcGIS Manager logs don't show any errors.
The issue: The service is not visible in ArcGIS Services Directory [3]. The cache has been cleared several times, the service restarted, and even the ArcGIS Server restarted (the stopserver and startserver scripts), but it just doesn't show up.
The would-be link [4] just gives the 404 error "Service '<servicename>' of type 'GPServer' does not exist or is inaccessible."
Any ideas on what to try next? (Maybe deleting the GP service and re-creating it)
Thanks in advance,
--Jarkko
[1] http://<servername>:8099/arcgismanager/
[2] http://<servername>:8399/arcgis/services/<servicename>/GPServer?wsdl
[3] http://<servername>:8399/arcgis/rest/services
[4] http://<servername>:8399/arcgis/rest/services/<servicename>/GPServer/
RaviNarayanan
If the service is running and REST cache is cleared, you should be able to see a newly created service listed in the Services Directory. Not sure why it is not in this case. If this is still an issue, can you please contact ESRI Support?
thanks
Ravi
JohnatanRojas
I'm having the same problem... Didi you find a solution for these ???
1. I have published a Toolbox with web access enabled through ArcCatalog, Not showing any problem.
2. I tested it in arcmap and everithing is working fine, however the service is not listed in the http://<server>:8399/arcgis/rest/services/<service_name>
Thanks.
DeeptiPuri
I have the same issue. Any solution???
