Export Map Image gives the red x marker
1221
07-30-2011 09:16 PM
GabiVoicu
I can not see the image via rest interface when i click Export Map Image - there is an X mark instead of the image....
Any ideas what it may me??????
Thank you
SrinivasVinnakota
Most likely virtual output directory was not configured correctly.
Also check if an output image is generated in the output folder when you call exportMapImage operation.
GabiVoicu
Yes the image gets generated in the output folder....
How should the virtual directory be configured properly?
this is the link to our arcgis server
http://gismaps.collincountytx.gov/ArcGIS/rest/services
Thank you
