ESRI doesn’t respond if there is any special character in search text.
1365
05-25-2017 11:46 PM
manishkumar2
  • Description:
  • Searched with a text “#1 boston” with findAddressCandidates api with langCode=EN.
  • ESRI returns error code 403.
  • ESRI Call:
http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates?SingleLine=...
Response:
ArcGIS REST Framework
Home
Error: Services Directory has been disabled.
Code: 403
JayantaPoddar
Code: 403
This error usually comes up when the REST directory is not accessible.
Are you able to make any successful query (even without special characters)?
How are you doing the query?
Think Location
manishkumar2
Yes, If I remove the special character "#" it works.
Response:
"candidates": [   {    "address": "Pho So 1 Boston",    "location": {     "x": -71.043648798999641,     "y": 42.163068841000495    },    "score": 95.5,    "attributes": {     "City": "Randolph",     "Region": "Massachusetts",     "Country": "USA",     "Postal": ""    },    "extent": {     "xmin": -71.048649999999995,     "ymin": 42.158068999999998,     "xmax": -71.038650000000004,     "ymax": 42.168069000000003    }   }  ]
JayantaPoddar
That's because there is no address with "#1 Boston" in World Geocode Service. Geocoded Addresses of USA are very precise and organized.
 When I tried "#1 Rajasthan", it returned an address.
Think Location
manishkumar2
I tried with "#1 Rajasthan". I still got error.
Can you share the url, I will try..
JayantaPoddar
You are right. It doesn't work on webpage. It worked for me in Geocoding toolbar of ArcMap.
Replacing # with * works on webpage.
Think Location
