Enhancement - Include "outFields" property on applyEdits or addFeatures
650
12-17-2010 05:54 AM
DanielBradshaw
In case anyone from ESRI is listening... The following would be extremely beneficial as an API enhancement:
Include a property "outfields" (or similar) on any of the edititing methods (applyEdits, addFeatures, etc) specifying the fields to be returned on success.  For example, instead of just returning the objectid and globalid when adding new features, it would be extremely beneficial if I could specify the fields I want returned, such as a user maintained ID field.
Otherwise, I find myself adding new features, then immediately having to query the database for the object I just created to gather fields that may have been updated via triggers (for example).  Two calls instead of one can sometimes be expensive.
Maybe there's an undocumented property out there that does this...??
RaviNarayanan
Daniel,
Thank you for this posting. Please submit your suggestion to http://ideas.arcgis.com if you have not already done so.
Ravi
