Can't get ResultImageLayer
646
05-17-2011 01:08 PM
CharlesSmith1
Hi all,
I am unable to get a ResultImageLayer.
I can get a GPFeatureRecordSetLayer using ResultData and add the feature geometries individually.
I am using ArcServer 10.1 so it is not a pre-release problem.
I can see the map service that accompanies the geoprocessing service and the legend / symbology in this map service.
I am doing this with the JavaScriptAPI.
Using Firefox I see a ???500 Internal Server Error??? but there is no other messages.
Could be as simple as my call:
gp2.getResultImageLayer(jobInfo.jobId, "Test01", imageParameters, addGPServiceResult2, errorProcessing)
function addGPServiceResult2(gpImageLayer) {
   map.addLayer(gpImageLayer);
I???m not sure what the ParameterName ???Test01??? should refer to although I???ve tried ever possibility that seemed reasonable.
Any help will be greatly appreciated.
Charles
RichardWatson
Look at the rest end point log as well.  You can adjust the level of detail in the rest.config file.
See REST API Logging at the bottom:
http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/config.html
ArokiyaJoseph
New Contributor III
Hi all,
Using Firefox I see a �??500 Internal Server Error�?� but there is no other messages.
I�??m not sure what the ParameterName �??Test01�?� should refer to although I�??ve tried ever possibility that seemed reasonable.
Charles
Charles,
I'm assuming you must have resolved this problem. But, 'test01' is the name of the output parameter.
