can not open services directory
6810
08-30-2011 07:41 PM
zhuzheng
today, i tried to excuted the exportwebmap task in the service directory. but it failed.  so i re-started the machine. then  i can not open the services directory. the error is blow:
Error
9017$SITE_NOT_INITIALIZED
Code: 500
i can log in the arcgis server manager. but the site panel have error, error info is :
Unauthorized
Unable to determine your user privileges. You are not authorized to view this content.
i have re-started my machine, rec-onfiged arcgis server account ,re-started the service of the arcgis server, re-authorize arcgis server.  all does not work.
Does everybody know this problem?
thank you very much.
RaviNarayanan
Zhu,
At the end of the installation of ArcGIS Server, you will be asked to "create a new site" or "join an existing site". Did the process of creating a new site or joining a existing site (based on the choice that was made) go as expected?
Ravi
zhuzheng
hi, today, i met this problem again, the version of arcgis server is 10.1 prerealse. i searched the error info in community. i find this thread i have asked last year. the problem is the same. this morning and yesterday i can use the arcgis for server correctly. but now i can not use it. i can not open services directory, the error is
Error: 9017$SITE_NOT_INITIALIZED
Code: 500
i can not connect the arcgis server in arcmap.
i have created the site and have published some service in it.
can any body met it ? thank you very much.
ChrisAdams
I used cloud builder to create a federated 10.3.1 instance. Today I get this error. I don't really want to create the AGS site again. Any help appreciated.
Unable to process request. 9017$SITE_NOT_INITIALIZED
ArcGIS Server Site is not configured. Check with your ArcGIS Server administrator for resolution; an ArcGIS Server site is created or machines are added to an existing site using ArcGIS Server Manager. Failed to return cluster lookup information. null
